Hello all,
I have had this problem occasionally and it's back once again. How is it that my visualizations no longer dance with the music? I have looked through the .ini file and found no settings to audio sync. Very few svp's look good with no audio stimulation. Any suggestions?
geposted Sat 07 Jan 12 @ 7:43 pm
I been using Sonique for years & never came across this issue. Did u do all the basic stuff, ie.. Reinstall/overwrite/replace the sonique svp files, deactivatre/reactivate VDJ settings to use Sonique for audio only files, restore/reinstall VDJ to default settings then reconfigure your settings. These are just some basic things that came to mind for me, I dont know if u already tried them. Good luck on getting it figured out.
geposted Sat 14 Jan 12 @ 3:03 pm
I had that happen when I started using a Hercules controller. If you don't have your sliders up it will affect how Sonique responds to the audio. You can control you volume with the master volume control.
Not sure if this is specifically your fix, but sharing my experience.
Anything else changed in your configuration?
geposted Sun 26 Feb 12 @ 12:18 pm
Thanks for the responses. I had changed from a Herc RMX to a Reloop Jockey 3. I reinstalled Sonique and all has been well. Still stumped as to why, but happy for now.
geposted Sun 01 Apr 12 @ 4:22 pm
