Hey guys,
When i load songs from my built in laptop hard drive they load and play fine.
But when loading them from my usb external hard drive virtual dj freezes for a few seconds then loads the song.
When this happerns the music keeps playing just the virtual dj software freezes briefly for a few seconds.
Thanks
Thanks
geposted Mon 09 Jan 12 @ 3:32 pm
The extrernal drive you have , does it have a power adapter with it or is it just usb ?>
geposted Mon 09 Jan 12 @ 4:39 pm
Its usb powered.
But it has 2 usb's to plug in. One for data and one for power
geposted Mon 09 Jan 12 @ 6:54 pm
Try a powered hub. You are using just the usb to power the drive, that could be it. I get little freezes from time to time and dont worry about it aswell, but mine are when loading on an internal drive..
geposted Mon 09 Jan 12 @ 8:05 pm
Yes you need to get a Powered Drive The Western Digital is a good hard drive to get
geposted Mon 09 Jan 12 @ 9:09 pm
That happens to me all the time. I have a powered hub and powered WD drives. I have learned how to deal with it so it doesn't affect my show...
DJ RuDe
DJ RuDe
geposted Mon 09 Jan 12 @ 11:23 pm
Put VDJ in higher priority (taskmanager, show tasks of all users, than click on the VDJ task and set the priority), that will give VDJ some advantage over other windows processes.
geposted Tue 10 Jan 12 @ 8:05 am
I don't have this problem ever, your drives should be 7200 rmp and also having them on a powered hub, does help your laptop function at full power all the time, one other thing may be that your ext drive is failing, I would download the Mfg. drive test software and check them out asap..
One more thing I would recommend to you is buy a serious hard drive, like a Glyph or a G-tech, yeah they cost more, but they last reliably longer..
Good Luck,
Joey....
Good Luck,
Joey....
geposted Tue 10 Jan 12 @ 8:06 am
Use to happen to me too.Do what I did, I switched to a firewire external drive, that fixed it.
geposted Tue 10 Jan 12 @ 8:32 am
Problem now solved.
I went into device manager, usb root hub and in the properties for power management i unchecked the box "allow computer to turn off this disk to save power"
geposted Tue 10 Jan 12 @ 10:45 am
If that works, great. WD drives had built in power managemenet. If it has been sitting idle for a little while the drive will spin down. When you load the song the drive will have to wake up causing VDJ to hang. I use this, saw it on another post on this site:
http://nosleephd.codeplex.com/
thanks,
David
thanks,
David
geposted Tue 10 Jan 12 @ 3:59 pm
Some hard disk manufacturers may provide a utility to change the built-in power management settings.
Otherwise, if this is not available for your drive and it takes too long to wake from sleep, the only option is to replace it with a different drive from another manufacturer that does not have this problem.
geposted Tue 10 Jan 12 @ 6:01 pm
Microsoft's default settings in most versions of Windows make you want to get in your car, drive up to Redmond Washington and go slap someone..hard. ;)
geposted Thu 12 Jan 12 @ 5:25 pm
Or if you buy a drive with builtin power management, just delete the partition, make a new one, format the drive and you're ready to go.
I'm using Packard Bell's Carbon drive's (both 1 & 2 Tb), and they come with PW management, so had to do it that way to keep it from powering down all the time...
Works fine...
Works fine...
geposted Thu 12 Jan 12 @ 6:20 pm
Deleting the partition won't help if the power management is built into the electronics/firmware of the disk itself (Or the USB controller card in the external hard disk enclosure.)
This has nothing to do with Microsoft either. It's a hardware/firmware feature in many cases (Although Windows has its own power management features that can easily be disabled.)
Many external drives are designed with typical home/office users in mind rather than DJ's who need the drive to wake very quickly.
geposted Thu 12 Jan 12 @ 8:21 pm
I use this program to keep my drive alive. Its written by a DJ for DJ's it sends a few bytes of info to the drive every couple of minutes thus keeping it alive.
Link: http://softjock.com/downloads/MDIS.exe
geposted Sat 14 Jan 12 @ 6:26 am
hey, i was having this problem nightmare tried this fix now nearly perfect just second freeze when i open my largest file thanks a lot
geposted Mon 09 Apr 12 @ 8:58 am
my turn....
i dont have this problem on my old asus b4 i reinstall vista on my old one and now i havent got any driver for internet , but thats a different story.
i have this problem on my new asus, g53 and same with mac... i dont get it.
geposted Tue 10 Apr 12 @ 6:04 am
@#1DJCavo, please do not spam the forum with posts like this!
Please have a look here:
https://virtualdj.com/wiki/Forum%20Rules.html
You post from above, is moderated!
geposted Fri 04 May 12 @ 6:51 am
