What are quality usb cables? what brand? I am curious to know if there is a difference in quality of gold plated usb and sliver plated. I would love to hear the opinion the the VDJ community.
geposted Mon 09 Jan 12 @ 6:45 pm
There's no real difference between Silver/Golden platted cables. However there's a huge difference when it comes to the stability of the USB port data rate depending on the thickness of the cable.
"High Quality" USB cables usually have larger diameter. They have more grid wires (richer mess) on the shield of the signal, and they also use thicker plastic isolation providing better shield/isolation from external interference.
Also if you are really troubled about USB ports stability try to use SHORT cables. Cables longer than 1meter can produce instability on the data rate especially if they are very "thin"
geposted Tue 10 Jan 12 @ 6:58 am
I use these and have had no problems at all.
http://www.amazon.co.uk/Belkin-Light-Cable-Green-1-8m/dp/B0002IK816/ref=sr_1_1?ie=UTF8&qid=1326203259&sr=8-1
Installs and works with the ease and speed of USB
Works with Hi-Speed USB 2.0 devices for high-speed data transmission
Helps you locate cables fast, in poorly lit areas or behind your CPU
Connects all your peripheral devices with a USB standard B plug to your computer or USB hub
Braid-and-foil shield construction reduces EMI/RFI interference
Lifetime Warranty
Manufacturer's Description
Belkin brightens up your desktop with our new USB Lighted Cables series, designed to provide you with top-level, error-free performance for reliable data transfers. This great new cable features A-to-B connectivity and builds in a special, low-power-consumption, super-bright LED that lights up the connector plugs in one of four colors. Perfect for easily locating the right connection point whenever you need it, the USB Lighted Cable brings a whole new meaning to the brilliance of Plug-and-Play simplicity.
Box Contents
Belkin USB 2.0 Light Cable with Green Led 1.8m
Lifetime Warranty
Box Contents
geposted Tue 10 Jan 12 @ 7:49 am
I use Monster Cables.
geposted Tue 10 Jan 12 @ 8:34 am
Thank for the info guys.
geposted Tue 10 Jan 12 @ 10:53 pm
