I need to connect VDJ to ustream to on air my music :( some one help me
geposted Thu 12 Jan 12 @ 4:08 am
i have the same problem help
geposted Wed 18 Apr 12 @ 6:20 pm
If using A mixer or controller and the controller/mixer has an extra output you can use that to route the music to ustream.
All you need is to have an AUX cable with RCA connection on one end and the headphone connection on the other.
You need to connect the rca to your mixer/controllers extra output and then headphone connection connected to the MIC input on the computer. Once that is done you can have music broadcasting on USTREAM. Now once connected to it you may need to tweak your MIC input and or ustream for best quality.
Hope this helps a bit
Charlie C
Charlie C
geposted Fri 20 Apr 12 @ 2:07 pm
