Hi,
I've just bought a Behringer 3000 and am having a little trouble getting it syncd with my laptop. I'm trying to use it in conjunction with Virtual DJ Home (Free) V.7.
I've downloaded all the appropriate USB Audio/MIDI Drivers for Windows 7 from the Behringer website (http://www.behringer.com/EN/Products/BCD3000.aspx). When switched on, if I look in devices the Behringer 3000 is under "Unspecified", but when I click on properties the device status is "working properly". So as far as I can tell there is nothing wrong with the driver or software itself.
However, when I open my version of Virtual DJ and click "Config", then "Mappers" the only option I get is "Keyboard".
I've tried messing around with the sound set up too, but with no success.
What am I doing wrong? Is it because I am using an old/the free version of Virtual DJ? If so which version do I need, and where can I get it?
Any help would be much appreciated, as my returns guarantee on the mixer will run out soon, and I need to decide whether it is worth me keeping.
Thanks!
Ben
Thanks!
Ben
geposted Thu 12 Jan 12 @ 11:54 am
you need to go here
https://virtualdj.com/products/comparison.html
geposted Thu 12 Jan 12 @ 8:51 pm
