I am considering getting the Numark Mixtrack Pro.
In my country it only comes with Traktor LE software which I do not want to use.
If I buy Virtual DJ Pro will it still have plug and play capability with the mixtrack or is there likely to be technical mishaps?
Also I would appreciate people who have the Mixtrack Pro posting their experiences with it.
Any advice is gratefully received.
geposted Sat 14 Jan 12 @ 5:26 am
mixtrack pro is natively supported, so once you upgrade you just need to plug it in and it will work straight away. you can get a discount on the upgrade as well if using your herc serial number probably between $30 - $50. Or you could get one from the USA that comes with vdj le and save $150 on the upgrade.
geposted Sat 14 Jan 12 @ 6:00 am
Thank you, I am considering buying from the US but the shipping is very expensive.
geposted Sat 14 Jan 12 @ 6:25 am
hi i have the vdj home free version but the mixtrack pro tells me it will only work for ten mins how can i fix this
geposted Fri 23 Mar 12 @ 9:51 am
By installing the LE-version that came with your controller or upgrade to the Full Pro-version. The 10-minute limit is one of the limitations the Free-version has. Please see: https://virtualdj.com/products/comparison.html
But hey: it's free ;)
If you register your LE-version, you will get a discount when you >>purchase<< the Full Pro-version.
geposted Fri 23 Mar 12 @ 10:09 am
