Hi
I'm running a VDJ-LE with a hercules RMX and have been for a while with no problems. Recently when i try to load a new track it freezes and comes up "not responding"
i have intel core i5 2.9Ghz (quad core i think) and 3GB RAM
any ideas what the problem could be
i have tried uninstalling it and re installing - no success
geposted Sun 15 Jan 12 @ 5:41 am
ps i have nothing else running on PC at the time
geposted Sun 15 Jan 12 @ 5:42 am
Have you tried a real unsinstallation of VDJ ?
- From the first winodow of the installer, select CUSTOM
- for every subsequent windows, choose SELECT ALL for every following ones
This will insure that all fines related to the software are removed ( the folder Virtual DJ should not be present in Document once the uninstallation is complete).
Then reinstall using the latest version (v5.2.2) which you will find in the Download section once you enter your serial number in your profile.
geposted Mon 16 Jan 12 @ 7:24 am
