Im having problems with my set up and not sure if its the settings in vdj... i am using 2x cdj2000 and a djm2000 with a macbook pro. so i hooked both cdj's to a usb port hub that goes to the laptop, since mac only has 2 usb inputs and i need more than 2. then i open vdj configure audio to external mixer and sound card to 4-out card and select cdj2000. now all the controls work fine but sound only come out of deck A... deck B plays but no sound comes out and when i look on my mixer there is no signal for that channel. is there somthing in the settings i have to change? or is it somthing else?
geposted Mon 16 Jan 12 @ 4:01 pm
What version of VDJ are you using?
The Home Free version does not support the use of Midi mixers or controllers.
Keith
Keith
geposted Tue 17 Jan 12 @ 1:45 pm
i am using the home free version.. and if i just plug the cdj's straight into the laptop without using the usb multi port hub, everything works perfect. except since its the free version it only works for 10 mins.... but my problem is that since mac only has 2 usb inputs i am using a multi port usb hub so i can plug my 2 cdj's and my external harddrive into the laptop. and when i do it that way sound only comes out of one channel and not the other. but the controls work fine, its jus a sound problem. and not sure wat it is.
geposted Tue 17 Jan 12 @ 6:37 pm
if ur using a free version and last only 10 mins. why would u wona try and fix this problem....
panos
geposted Sat 21 Jan 12 @ 10:12 pm
lostgrave22 wrote :
i am using the home free version.. and if i just plug the cdj\\\'s straight into the laptop without using the usb multi port hub, everything works perfect. except since its the free version it only works for 10 mins.... but my problem is that since mac only has 2 usb inputs i am using a multi port usb hub so i can plug my 2 cdj\\\'s and my external harddrive into the laptop. and when i do it that way sound only comes out of one channel and not the other. but the controls work fine, its jus a sound problem. and not sure wat it is.
You can't control multiple USB Device and let it works simultaneously by just plugging it into the USB HUB each of them must mapped to VDJ. Please try to purchase the VDJ pro and it works for you. I have just did a setup of CDJ-2000 & DJM-2000 for a small club recently like this:
 Diagram123.jpg)
Sorry it is not allowed to shared any technical drawing or info data to not registered user. If you have VDJ pro registered i will send you the clear copy of this plan drawing and you can download the mapper in the VDJ download area.
geposted Sun 22 Jan 12 @ 4:37 pm
