Hi ! The question is simple... Is there a way to monitor what key is the song that i'm playing on VDJ and what key it becomes when i change it from the key knob?
geposted Tue 17 Jan 12 @ 6:22 am
Yes, and on the default VDJ skins it shows like below. Once you move the pitch slider it changes the key.
Note: If you have already done setting up the BPM thru the Pitch slider and if keys display is not the same as on the other deck that is playing you can use the knobs to match the key of both decks.
geposted Tue 17 Jan 12 @ 7:57 am
