Hello
Is there an official standard VDJ7 skin in 1920x1080 resolution?
If there is, I can't seem to find it... Directions would be appreciated :)
Best regard
Klaus Mogensen
Best regard
Klaus Mogensen
geposted Tue 17 Jan 12 @ 6:26 am
At the moment there are no 1920x official skins. You may use some of the custom made ones.
https://virtualdj.com/addons/skins.html?category=all&order=default&resolution=1920&search=
The first 2 in the list have layout similar to the default ones
geposted Tue 17 Jan 12 @ 10:31 am
Here's one for VDJ6 in 1920x1200
Assuming it has all the features you need it can be reduced to 1080 height with the skin resizer tool or you will just lose a bit of the browser off the bottom of the screen.
https://virtualdj.com/addons/8472/VirtualDJ_6_-_1920x1200.html
Keith
Keith
geposted Tue 17 Jan 12 @ 12:51 pm
