I am using the NS6. I want to know how to map the volume slider on of the sampler to a knob on the NS6. Thanks in advance for the help.
geposted Wed 18 Jan 12 @ 6:30 pm
I just copied this from a thread I answered today it is relevant to your request..
https://virtualdj.com/forums/159600/Hardware_Technical_Support/Mixtrack_Pro_sample_playback_volume.html
unfortunately the sampler volume isn't linked to the master or even the deck volume... I suggest you use "mp3 gain" on all your samples to have them at the same level, then you can map your sample volume knob/slider to this if you want to change all the levels at the same time.
"sample 1 volume & sample 2 volume & sample 3 volume & sample 4 volume & sample 5 volume & sample 6 volume & sample 7 volume & sample 8 volume & sample 9 volume & sample 10 volume & sample 11 volume & sample 12 volume"
or you can map it with this if you just want to change the level of the selected sample on the skin
"sample volume"
"sample volume"
geposted Wed 18 Jan 12 @ 7:06 pm
thank you very much.
geposted Wed 18 Jan 12 @ 7:38 pm
That script is a little wrong... It should be "sampler" not sample. Also, if you use a program like MP3 Gain to set a default level for your whole music library to include your samples, you shouldn't have any problems. I load my whole music library in and let it run over night while I sleep. A have a constant volume level for ALL of my music, videos, and samples. Works flawlessly for me using a RMX.
geposted Mon 01 Apr 13 @ 9:01 pm
