I am new to the whole world of midi controllers and digital Dj'ing but I have come to the understanding that it is possible to "Map" the keys on a DJ controller to perform certain functions in a software. I'm looking into the VMS4.1, but don't feel the need for the 2 extra decks (which i heard are mainly for if you have a computer crash and need a back up, correct me if I'm wrong). Anyways, I was wondering if it is possible to map the eq section and faders for the third and fourth decks to perform other functions such as samples, que points, effects etc in Traktor Pro. Any help would be great.
Thanks
I'm not looking for any Mappings just wondering if this can be option if I do purchase the VMS4.1
Thanks
geposted Thu 19 Jan 12 @ 5:22 pm
First off - are you asking in the right forums?
You asked about Mappings - but the title says 'Traktor' ...
So, which is it - VirtualDJ Mappings or Traktor?
geposted Thu 19 Jan 12 @ 5:27 pm
My apologies, i meant to say virtual DJ, but am wondering if the same thing can be applied to Traktor as well.
geposted Thu 19 Jan 12 @ 5:32 pm
Yes, if you purchase VirtualDJ PRO you will be able to re-map any of the elements on the unit to do other options. But you will need the PRO Full version to do this.
geposted Thu 19 Jan 12 @ 5:35 pm
Thanks, and in terms of Traktor its the same?
geposted Thu 19 Jan 12 @ 5:36 pm
yes is the answer no mater if it's for Traktor or VDJ they also send midi so if not used anyway for audio why not take them in use for other purposes. Any way you can use all 4 decks in VDJ and Traktor and in traktor you could deck C/D or 3/4 depends on what you call tem to controll the sample players.
anyway http://www.djtechtools.com/forum/ would be a better place to ask about traktor or even NI forum
On another note, is there advantages to having 4 decks when not using any extra ipod/turntable/cd hookups?
geposted Thu 19 Jan 12 @ 5:40 pm
4 decks can be used in many ways for mashups you could have the accapella. a beat in one then an other song in the 3. and a 4. could be used for a cool hook lick to use as a chorus. or cue point juggling between all 4 decks there are endless options. at first I only used 2 decks but as I got used to my VMS4 I started adding the extra 2.
you can still have a setup of 4 decks and have cd or ipod connected to a channel just switch on the front from usb to analog and you can use the external source.
geposted Thu 19 Jan 12 @ 5:56 pm
Hi! Simple question:
I've got an American Audio VMS4.1
Can i add the 'Sampler' function from VDJ on channel 4 of my mixtable? (on the VMS4.1)
Thank you
ERic
Thank you
ERic
geposted Sat 15 Jun 13 @ 7:06 pm
I thought it was already mapped to sampler function? Either way, to customize mappings in VDJ you will need the Pro version..
https://virtualdj.com/products/comparison.html
geposted Sun 16 Jun 13 @ 2:09 am
c est domage mais mon controlle American Audio VMS4.1 re connaît pas tout sur le virtuel dj pas posible de configurée la mapping c est pour sa que je utilise plus le virtual dj
geposted Thu 03 Dec 15 @ 7:27 pm
This is an English speaking forum only. Please try one of our other forums, that may have a language that you can understand, thank you.
geposted Thu 03 Dec 15 @ 8:02 pm
