Vestax VCI 400
geposted Sun 25 May 14 @ 4:29 pm
VMS4.1 gets my vote - I've had mine a couple of years, and it's never let me down. We had a customer bring one back to the shop for repair after an accident at a houseparty - some idiot had managed to pour a pint into the thing. I stripped it down, cleaned the boards with distilled water, replaced one fader, put it all back together and it was good as new. The VMS4.1 is a hardy beast it would seem.
geposted Sun 25 May 14 @ 4:38 pm
agree...have 3 of them....very reliable controller...
geposted Mon 26 May 14 @ 1:35 am
Do you need them to be XLR, or do you just need them to be balanced output?
If you just need the balanced output (which is easily converted to balanced XLR - I do this all the time) then the Reloop Terminal Mix 2, Terminal Mix 4 and Terminal Mix 8 are also possibilities - and I personally love these products
But please notice that the TM8 hasn't been mapped to VDJ8 yet...
geposted Mon 26 May 14 @ 2:01 am
Did you guys not notice that this thread was started over two years ago?
I should think the OP has bought something by now... :-)
geposted Mon 26 May 14 @ 5:57 am
we do...but someone grabbed it up 2013...;-)
geposted Mon 26 May 14 @ 6:04 am
Can a mod please delete my email address from this thread.
Thank you
Thank you
geposted Mon 26 May 14 @ 1:53 pm
Done
geposted Mon 26 May 14 @ 2:45 pm
vms 4.1 great controller
geposted Mon 26 May 14 @ 3:23 pm
Which DJ Controllers with 3 Way XLR out (Left, Right, Subwoofer) ?
geposted Sat 31 May 14 @ 10:59 am
For $300.00, the Hercules RMX2 is a great workhorse. The sound quality is great, the jog wheels work well with VDJ, it is compact and has the XLR output you're looking for.
geposted Sat 31 May 14 @ 11:23 am
Hercules RMX2 only two output (L+R) not XLR for SubWoofer...
geposted Sat 31 May 14 @ 1:40 pm
Controllers normally do not have outputs like this. Most have standard master out left/right. In some cases, they may also have a booth output that you could utilise for the subwoofer.
However, with a powered subwoofer, this should usually have thru connections so that you can run cables from the master outputs of the controller to the sub(s) and then another set of cables from the thru connectors of your subs to your speakers.
Otherwise, you should use a crossover such as http://www.behringer.com/EN/Products/CX2310.aspx - This will give you more control over the sound that's sent to each speaker, so the sub only gets the low frequency bass and the speakers get the rest of the frequency range.
geposted Sat 31 May 14 @ 2:01 pm
Here is how I address the subwoofer issue. I use an EQ with a separate output, dedicated to the sub, like one of these, http://www.pssl.com/Behringer-FBQ-1502-15-Band-Graphic-Equalizer
geposted Sat 31 May 14 @ 2:34 pm
geposted Sat 31 May 14 @ 3:56 pm
