I Use a numark Mixtrack with VDJ 7.
i was wondering, is there a work around to use 4 decks controll with this.
Regards
Deejay Manas
Regards
Deejay Manas
geposted Mon 23 Jan 12 @ 4:24 am
Yes, if you upgrade to the full VirtualDJ Professional at a discount then you can use 4 decks by mapping buttons to toggle between them: https://virtualdj.com/buy/
See: https://virtualdj.com/wiki/Controlling%204%20decks%20with%20a%202%20deck%20controller.html
geposted Mon 23 Jan 12 @ 6:55 am
I took a look at it and can get the mapping for using the PFL button. But I would like to use my Pitch Bend buttons to switch between decks and can't figure out how to do it.
geposted Tue 27 May 14 @ 11:58 pm
