Iam new to using this midi controller and would like to know the best way to connect the outputs direct to my Amp which has RCA or Jack inputs . The info in the Hercules manual does not really show the best way to connect. If it is Jacks 1/2 outputs should this be the t/r/s type jacks etc? Any help to me would be graet. I will be using it for clubs and pubs etc.
geposted Mon 23 Jan 12 @ 12:44 pm
As far a I know you just hook up your 1/4 inch jacks to your
Main input on the amp and then take what ever connections from the amp to the sound sonic it's 1/4 inch jacks then that's the route you have to go I don't think it has to be the trs jacks cuz it's blanced out from the rmx. But Don't qoute me on (im still new to the world) but that's they way I hooked up when I was playing off of the band sound system one might.
geposted Mon 23 Jan 12 @ 5:38 pm
