Hi guys, in abit of a rush.
Want to use Virtual DJ 6 on my pals Mac which runs 10.7 and I've got a gig tonight.
Just bought a second hand Audio 8 DJ sound card and I was wondering what the set ups were? Is it just plug and play through channels A and B?
Will be using CDJ 1000 mrk 2 and a DJM 600
Any help would be great!
G
G
geposted Thu 26 Jan 12 @ 1:35 pm
I use mine with a PC so it may be alittle different on a MAC but yeah in the setup window itll be 1/2 for deck 1, 2/3 for deck 2 and 4/5 for the sampler. Im not at home but that should be it.
Hope thats some help
Huey
Huey
geposted Thu 26 Jan 12 @ 6:21 pm
Still having trouble with the set up.
On the Soundcard option in "Set up", the only way option it gives me is to select the "4in4out" then click audio 8 from the drop down list, but nothing seems to work.
The sound card indicates that its recieveing a signal from the CDJ, but nothing happens on screen.
Using Virtual DJ Pro 6 on a Mac running the new Lion OS.
Any help would be helpful!
geposted Thu 02 Feb 12 @ 7:56 am
VirtualDJ Pro v6 is a very old and out of date version of the software. There have been many changes and improvements to the software since then (See https://virtualdj.com/wiki/VirtualDJ_History.html ) - We are now on v7.0.5b
Please register your serial number on the page https://virtualdj.com/users/edit.html and then upgrade to the latest version: https://virtualdj.com/download/updates.html
If you haven't purchased VirtualDJ Pro, please support the software and its future development by purchasing it: https://virtualdj.com/buy/
You can try it out for 10 minutes a time before purchasing with the latest Home FREE: https://virtualdj.com/download/free.html
The cause of your problems is most likely due to using such an old version.
geposted Thu 02 Feb 12 @ 9:52 am
I use my audio8dj since ..i don't know , but maybe 3 years , without a problem ...Time code with Serato vinyls is amazing !
geposted Thu 02 Feb 12 @ 6:40 pm
