Is there a way to do this and where would I read about it ? I need to do that and link ten other things.. with out it crashing.... im also looking to add novation pad ..... and want it all to work as a single system and be able to understand one and each other.. or is there a new tool like that comming to virtual dj so that we can make samples (64) into playable screen mixs.. I have ten timmys new 24 oz and my pjs on lets not sleep till it works...
geposted Sun 29 Jan 12 @ 10:25 pm
shouldn't take too long... LOL
just go into advanced config and set up a "rewire ableton" channel
I cant remember the order you start the two programs, but I think its ableton, connect the launchpad to it. then open vdj connect your dj controller. then I just used deck four for ableton by mapping "deck 4 linein"
that should be it... vdj will send the beatgrid to ableton and the play pause pitch etc... will control abletons transport, i didn't test it extensively but it worked pretty well. there are a few threads on it within the forum, try searching
site:virtualdj.com ableton rewire
geposted Sun 29 Jan 12 @ 10:38 pm
@bigx_gr: Please do not hijack a topic by posting a message that is not related in any way.
Please create your own new topic (Click on the pen and paper icon at the top of the forum topic list) and use the appropriate forum, which would be Music Discussion for the message that you posted: https://virtualdj.com/forums/16/Music_discussion.html
Please also don't post the same message more than once.
geposted Mon 30 Jan 12 @ 1:59 pm
