Is there a way to export a playlist from virtual dj on my Mac Pro to virtual dj on my macbook pro?
geposted Mon 30 Jan 12 @ 10:09 pm
you need to have the music in exactly the same file path then just copy the playlists folder (in the vdj folder) or the individual playlist files over to the new laptop.
if the filepath has changed between the two laptops you can open the playlist files with a text editor and make the necessary changes there. or you may be able to use the playlist fixer plugin if it is available for mac.
geposted Mon 30 Jan 12 @ 10:18 pm
