Topic: HELP SOMEONE!@
I HAVE A THE SKIN MIX STATION TC 05 POWERED BY MAURICIO BRAIDA.
THERE IS NO BUTTON FOR CONFIG OR GO BACK TO CHANGE SKINS IM LOCKED OUT.
someone please help me I cannot change this skin ..
i guess ill have to redownload vdj :(
please help ?
geposted Tue 31 Jan 12 @ 5:33 pm
quickest way to help with your issues with VDJ are here:
CLICK ME!
that doesnt solve my problem :( someone
pleaasee help!
Goto MyDocuments\Virtualdj\Skins. Delete that skin. Launch Virtualdj. If that doesnt load the default one, re install the software.
You are using a very old skin , buyt i can see Config Buttom:-)
At the top to the left ; FX , SAMPLE , REC and ........... SET (Settings or config)
BTW : Buy the software .
You can choose your default skin with Registry_Tool , only for Pro users ;-)
[tread locked oct 2013 - someone posted spam so it got bumped for no good reason ]
