Am using a mac and the ns6 also kontrol x1 am having issues when I play music on vdj program will close out on me it doesn't crash or freeze it just closes out after awhile of music playing . Step i done is reinstall vdj and still the same problem I use to own a mixtrack pro and a rmx never had this issue . my mac spec are
Model Name: iMac
Model Identifier: iMac11,2
Processor Name: Intel Core i3
Processor Speed: 3.06 GHz
Number Of Processors: 1
Total Number Of Cores: 2
L2 Cache (per core): 256 KB
L3 Cache: 4 MB
Memory: 4 GB
Processor Interconnect Speed: 5.86 GT/s
I also have itch should i remove it ? please help thanks
Model Name: iMac
L3 Cache: 4 MB
Memory: 4 GB
geposted Wed 01 Feb 12 @ 6:55 pm
Have you tried updating NS6 Driver from ITCH?
geposted Wed 01 Feb 12 @ 11:05 pm
Yes
geposted Thu 02 Feb 12 @ 12:08 am
After VDJ closes, try to re-open repeatedly until it stops closing automatically.
Or...
With VDJ closed, go to preference, audio-midi, select Numark USB Audio and set it as your input& output soundcard. Open VDJ, go to config, audio sttings, and use Numark USB Audio as your soundcard. Otherwise, you might need to do a clean uninstall and then re-install.
Hope this'll help.
Or...
Hope this'll help.
geposted Fri 03 Feb 12 @ 6:05 pm
