I have used a few skins that have a "Automix" button that when right clicked it will start the other deck and move the fader control over,is there a way to do this on a skin that doesn't have this button by using the keyboard?
geposted Wed 01 Feb 12 @ 8:37 pm
in config go to mappers choos keyboard and then key learn then type in action field mix_now or mix_now_nosync depending on if you want the songs to auto sync or not
geposted Thu 02 Feb 12 @ 12:25 am
Thank you I will give that a try.
geposted Thu 02 Feb 12 @ 5:01 am
Thank you Gullum that worked out perfectly for me.
geposted Mon 13 Feb 12 @ 9:03 pm
