Hi fellow VDJ users :)
I am using VDJ7pro and is very pleased with it, although i have a simple problem . . .
I use VDJ7 with timecodes, but i will like to use 3 cdj players to control the 3 decks(perhaps 4, when a forth player is available)
For the time being the only way i can get it to work without any dropouts is with the standard setup with input selection with timecodes, mixer/3channel mixer out.
Everytime i try to set up and advanced config i get it laggy as hell. I tried to set the latency different, but the only latency setting that works perfect is the ultra setting which is not available when using advanced config.
So my question is, how do i get 3 or more timecode signals to work?
Hardware:
Soundcard: A&H DB4 mixer as soundcard.
PC win7:
Lenovo T410
I7, 8 gigs ram, ....
Hardware:
PC win7:
Lenovo T410
geposted Mon 06 Feb 12 @ 2:55 am
