can someone help please,
When i download vdj onto my laptop it downloads with all the regular stuff and you follow all the steps to install it and then gets to the click to finnish then launch button!!! after that it sometimes brings vdj up to use but when you click off it all together it will dissapear and the program hasnt been installed at all and no short cut either, and also sometimes when you unpack and run the folders after it will say that it hasnt been installed with the right settings!
im so confused as my laptop wont allow it to install can someone please help??
geposted Mon 06 Feb 12 @ 3:42 pm
I don't understand exactly what you are trying to say, but you should try to install the program as ADMIN
Right cllick on the download thing and choose "Run as administrator"
You say one time it opens and other time it doesn't and it isn't installed at all, that part confuses me.
If it's installed the first time, you should have no problems anymore.
If I'm wrong, please enlighten me and others and try explaining your problem in another way so we can all understand it ;)
geposted Mon 06 Feb 12 @ 5:26 pm
