Is there a program out there that can get the key form of a song and organize them by key and bpm? I know of a couple but they only do one of the two,the rest have to be done manually by creating a playlist. I'm trying to organize my music by key and then by bpms.
geposted Mon 06 Feb 12 @ 5:33 pm
VDJ does this...
I arrange all my music by key and or bpm...
You just have to right click on your colums, it's there ;)
geposted Mon 06 Feb 12 @ 5:39 pm
I know,I've organized and by bpm and by key but you can't do both at once. what i want is: A 125 BPM,B 126 BPM,C128 BPM,D 130 BPM and so on. Or do I have to do this manually?
geposted Mon 06 Feb 12 @ 6:29 pm
Google "Mixed In Key"
geposted Mon 06 Feb 12 @ 9:36 pm
Thanks beatbreaker1,I looked into that before but it doesn't do what I want. Mixed In Key gets the Key and the BPM but it doesn't do this: A 125 BPM,A 126 BPM,A128 BPM,A 130 BPM. My question is if there is a software out there that will get the keys and organize them by bmp,instead of just bpms or just keys?
geposted Tue 07 Feb 12 @ 11:31 am
you can already sort using two different column's... if you want to move the tracks into folders just highlight and drag them holding ctrl
geposted Tue 07 Feb 12 @ 12:15 pm
Thanks Synthet1c,that sounds pretty close to what I'm trying to do,I'll try it when I get home.
geposted Tue 07 Feb 12 @ 3:57 pm
Lovin' your recordcase track comments there, synth....
geposted Tue 07 Feb 12 @ 4:32 pm
geposted Tue 07 Feb 12 @ 4:50 pm
To help DJs learn harmonic mixing, Mark Davis created the Camelot wheel, a visual representation of which keys are compatible with each other:
http://www.harmonic-mixing.com/HowTo.aspx
geposted Tue 07 Feb 12 @ 5:20 pm
Before VDJ started detecting the key, I used to have that Camelot wheel filling my desktop for use with MIK. ;)
geposted Tue 07 Feb 12 @ 8:20 pm
