Can I search for songs by what key they are in? i.e A, B D#
geposted Tue 07 Feb 12 @ 8:26 pm
Hi,
You can do that with a filter-folder. see here
Best regards,
John
Best regards,
John
geposted Tue 07 Feb 12 @ 11:46 pm
Left click on BPM if that's how you want to do the search,if you want to do it by key or numeric key,right click on one of your columns (BPM,Artist ect) and add the new column by which you want to do the search.
Good luck!
Good luck!
geposted Wed 08 Feb 12 @ 6:37 am
Thanks guys!
geposted Wed 08 Feb 12 @ 8:51 am
Or just look in your browser for a folder named "Compatible Songs" or something to that effect. All the tracks in the folder will match the bpm and key........
Good Luck
Huey
Good Luck
Huey
geposted Wed 08 Feb 12 @ 9:27 am
Thanks Huey!
I have never noticed that folder "compatible songs" I like that
geposted Wed 08 Feb 12 @ 12:47 pm
Neither did I,when I got home I tried to open it and there's nothing in it. Is there something wrong with my settings or do I need to do some tweaking?
geposted Wed 08 Feb 12 @ 4:50 pm
Load a track and then the tracks will show up in there, lol. They should be the best ones to mix with the playing track. It's not perfect but it'll get you pretty close. I've even found tracks that I never thought mixing together.
Holla back
Huey
Holla back
Huey
geposted Wed 08 Feb 12 @ 5:39 pm
LOL! I figured it out a few minutes after I posted the comment. This is exactly what I was looking for in VDJ without having to pay for a new software. Thanks a lot Huey,the help is much appreciated as alwasys!!
geposted Wed 08 Feb 12 @ 5:50 pm
Huey
I am grateful too but.....
When it gives me suggestion the keys are all over the place. I wonder how it knows which songs to pick?
geposted Wed 08 Feb 12 @ 10:39 pm
if you right click the filter, and choose "change filter" it says
bpmdiff<=4 and keydiff=0
so it means tracks within 4 bpm of the playing track so a range of 8 bpm in total, where it says "keydiff=0" that actually means one camalot higher, lower and the same
you can make your own filters with info from this page https://virtualdj.com/wiki/FilterExamples.html
my personal favorite is for finding quality tracks fast when needed is
rating>=4 and bpmdiff<=5 and keydiff=0
its the same but excludes anything with 3 stars or less
geposted Wed 08 Feb 12 @ 11:35 pm
