An user have 2 new Cdj700 (Gemini) .
The Cdj comes without Asio Drivers (no Cd in the box)
He is asking in the spanish forum about Vdj+Gemini cdj700 .
any ideas ?
Thanks in advance .
any ideas ?
Thanks in advance .
geposted Wed 08 Feb 12 @ 9:00 pm
probably start with gemini support...
http://www.geminidj.com/tech-support
I checked their cdj700 page, but the only downloads were mappers for vdj and traktor, it didn't look like there was anywhere else to download drivers and firmware. they didn't even have the manual available...
they may also need to switch the device from cd or midi to HID to get it recognised
http://www.geminidj.com/cdj-700
they could also try asio4all, that should do the trick until a real solution presents itself if the other things don't work
geposted Wed 08 Feb 12 @ 9:35 pm
The Gemini website has the link to download the ASIO drivers, and they already mapped to Virtual Dj.
geposted Thu 05 Apr 12 @ 12:11 pm
it depends if he is using a mac or a pc
mac dont need asio drivers plug and play just need to adjust settings with in virtual dj
pc needs asio driver and the program is on gemini website. if he has a 4x4 sound card just plug it in like normal and usb for midi control plus he will be able to have the function of dvs as well and also incase he gets the bsod he can quickly pop in a cd or usb and get of trouble
geposted Tue 23 Oct 12 @ 5:30 pm
