Hello, I just got a vci 100 for a cheap deal, actually very nice sturdy controller. My question is when you spin the vci platter one revolution the vdj vinyl spins several revolutions . Is there a way to make both of them the same, more accurate .. for example one revolution on the vci equals one revolution on vdj vinyl.. thanks Jon
geposted Thu 09 Feb 12 @ 10:05 am
that is very weird... map a keybaord key to
deck left wheel_mode "jog" & deck right wheel_mode "jog"
press it and see if that fixes it as it might be on "search" or something, if not change the jogwheel mapping to something like
param_multiply 20% & touchwheel
that will divide the amout the jog moves the track position by 5, the smaller the value the less sensitive the jog will be. there is also a slider in the config menu that you can adjust the sensitivity of the jog
geposted Thu 09 Feb 12 @ 7:14 pm
Please don't post the same message more than once. You have also posted the same message in the Hardware Technical Support forum:
https://virtualdj.com/forums/160573/x/
I will leave this topic open and close the other duplicate one.
You can more easily adjust the jogwheel sensitivity using the sliders in CONFIG -> Options.
geposted Fri 10 Feb 12 @ 10:12 am
