hi i have some mp3 files that when i load them into VDJ they are up to 5 or 6 times longer than they should be eg 6mins in itunes 28-30mins in vdj if i play file then click through it quickly on play bar some times go back to correct lenght. very annoying when trying to mix any thoughts on the problem ?
geposted Fri 10 Feb 12 @ 10:16 am
re-analyse the file (under the BPM section)
geposted Fri 10 Feb 12 @ 10:54 am
If you have VBR (Variable Bit Rate) files, then they the length will be initially shown incorrectly until you load them to a deck in full or analyse them.
To avoid this, pre-analysing your music collection is strongly recommended. Please see:
https://virtualdj.com/wiki/Pre-Analysing%20Your%20Music%20Collection.html
geposted Fri 10 Feb 12 @ 11:39 am
