i used Hercules 4MX and it's work perfectly and i'm to Numark N4 for some reason
Comparison
SOFTWARE WISE
Hercules 4MX - Virtual DJ and Traktor
Numark N4 - Virtual DJ, Serato and Traktor
its your choice
Comparison
SOFTWARE WISE
its your choice
geposted Mon 19 Nov 12 @ 10:36 am
JD WAS wrote :
I find that the deck swap makes 4 deck mixing almost impossible.
That's funny, I have no problem mixing with 4 decks using the 4-MX, heck, never had an issue doing it with the RMX, Trust me, very POSSIBLE!
As for the N4 or the 4-MX, regardless of the 2 or 4 upfaders, you still have to choose which deck to use by pressing a button. either A to C/ B to D or Decks 1,2,3,4 ;)
Dude, you're a winner with either one, just make sure you get your skills up to par, that's all!
geposted Tue 20 Nov 12 @ 2:51 pm
N4 buy it you wont regret it..
geposted Tue 20 Nov 12 @ 7:55 pm
Agreed! This is strictly my opinion--and I don't mean to offend any Hercules fanboys out there (and this is coming from a someone who used Hercules product for almost 3 years)--but the small platters on the Hercules are annoying to work with, the tactile control is much to be desired. The N4 has wonderful platters to grab onto, perfect size. Ultimately it is a matter of preference; I'm sure there are those out there that find the bigger platters unappealing.
geposted Wed 21 Nov 12 @ 2:45 pm
