stanton scs1m stanton scs1d system
geposted Mon 13 Feb 12 @ 12:52 am
Don't them screws get in the way when your cuttin?
geposted Mon 13 Feb 12 @ 8:57 am
no the crossfader of scs1M have 0.6 cm or more of void
so nothing happen when you move a little the crossfader so grabb is impossible
with that screw, the void of the crosfader is full and just you move the crossfader a little and the midi message is come to the software
now with that the crossfader is very very good for scratch
geposted Mon 13 Feb 12 @ 10:00 am
sidraz wrote :
scs1M have 0.6 cm or more of void so nothing happen when you move a little the crossfader so grabb is impossible with that screw, the void of the crosfader is full and just you move the crossfader a little and the midi message is come to the software
Need a bit of thinking not just put screw and mounts. BAD AND UGLY SCREW USED IN MOUNTING!!! Doesn't look nice....
You should use the FLATHEAD SCREW that will level on the surface when mounted.
geposted Mon 13 Feb 12 @ 10:41 am
@sidraz
Your original Post was moderated. Do not post links to external self promoting sites.
As a Licensed users you have VirtualDJ blogs you can share this kind of content in.
Hopefully you will purchase a license soon.
Cheers.
Cheers.
geposted Mon 13 Feb 12 @ 12:17 pm
