Colleagues,
Trying to get a new laptop set up with my system. Running 7.0.5b Pro (b380) on a Toshiba Qosmio X775.
I plug in my Denon DN-HC 4500 contoller but am not able to have it recognized under the config sound setup.
I see the XML file for Denon HC4500 mapping under the plugin options from the VirtualDJ website. But I am not sure how to get this all synced up.
Under previous versions of Virtual DJ, I remember there being a list of options under the Controller tab and I could simply scroll down to select the appropriate controller interface. How do I do this now?
Thanks in advance!
--Rob Clark
Thanks in advance!
--Rob Clark
geposted Mon 13 Feb 12 @ 10:58 am
It's natively supported, so should work plug and play.
Please ensure that you have the latest VirtualDJ Pro v7.0.5b installed from the Download Center: https://virtualdj.com/download/updates.html
And the latest drivers and firmware for the HC4500 installed from http://www.denondj.com
If you have installed an old mapper, then this may be conflicting with the native support, preventing it from working. Try removing the custom mapping: https://virtualdj.com/wiki/Reset%20controller%20back%20to%20default%20factory%20mapping.html
There could also be a MIDI conflict on your computer. Please see: https://virtualdj.com/wiki/midinotdetected.html
geposted Tue 14 Feb 12 @ 9:22 am
