I'm trying to download the Mixlab skin, but I am met with a message saying that my 'current licenses do not allow me' to download it. All I want is a skin with a bassline crossfader.
How do I download a skin, now that it appears I've blown $120 in upgrading from Home Free to Pro Basic?
geposted Tue 14 Feb 12 @ 1:01 pm
You haven't blown anything: according to >>THIS<< you should be entitled to download skins. Check your profile (Modify my profile, scroll down a little) if your Basic-version is mentioned. If not try to enter your serial number and click Register. If that doesn't work, submit a ticket under Support/Help and have support take a look at your problem.
geposted Tue 14 Feb 12 @ 1:35 pm
I'm sure you should be able to download skins with Pro basic.
Please submit a support ticket here: https://virtualdj.com/contact/
Thanks - Keith
Thanks - Keith
geposted Tue 14 Feb 12 @ 1:45 pm
Make sure that you are currently logged into the VirtualDJ website/forums before trying to download, otherwise you will not have permission.
It's also possible that you were trying to download before you had registered your Pro Basic serial number to your profile (You have done this now, so should be OK.)
geposted Wed 15 Feb 12 @ 4:47 am
