Hello there:) I am trying to create a skin and i am stuck:)
My problem: I want to create a "circle song pos" around the plattern as the original vdj skin but without effect of songpos (move song around_
I have try some thing with <visual (using clipmasks) but nothing). I want that as i want to be able to scratch over it with the "needle" beeing over the song pos:) any idea??
geposted Tue 14 Feb 12 @ 2:13 pm
You should use MOUSEMASK, not clipmask. Clipmask will provide a mask for the graphics to be visible or not. Mousemask will provide a mask that will tell VDJ whether the mouse is on top of an element or not...
More info: https://virtualdj.com/wiki/Skin%20SDK%20.html
Wiki wrote :
<clipmask x="" y=""> : Give the coordinate of the B&W graphic that should be used as a clip mask when drawing the button
<mousemask x="" y=""> : Give the coordinate of the B&W graphic that should be used as a mask to decide if the mouse is over the button
geposted Tue 14 Feb 12 @ 10:44 pm
ok I did it:) I was thinking something with visual and not for songpos with "all white" mouseover mask. Now as I add some rotation over it it seems not to work.. I want something like serato (needle above songpos)
geposted Wed 15 Feb 12 @ 9:53 am
You cant have songpos and rotation to overlap. It wont work.
geposted Wed 15 Feb 12 @ 1:02 pm
I see:) thx for support anyway:)
geposted Wed 15 Feb 12 @ 5:33 pm
