I reinstalled Virtual DJ from backup after my system crashed. Now when I launch VDJ the window is full screen size. I cannot access the "minimize" tab. The only thing I can do is close the program or use the Windows Start button on my keyboard to show my task bar. Is there a setting somewhere to fix this? I can't find a "preferences' tab any where.
Thanks!
Thanks!
geposted Wed 15 Feb 12 @ 7:19 am
have you tried going into config > skins tab > selecting an alternative skin size.
geposted Wed 15 Feb 12 @ 7:22 am
Where do I find config?
geposted Wed 15 Feb 12 @ 8:29 am
The skin is not the right resolution for your screen and will give you performance issues. To be able to see the configuration button to change the skin and the other buttons at the top do the following :
Press control + alt + delete
Select task manager
Select applications tab and select Virtualdj
Now select windows at the top and select maximize
This should force the Virtualdj skin to fit to screen so you can access the configuration menu
Hope this helps, and let us know if it works for you?
Ian
Select task manager
Ian
geposted Wed 15 Feb 12 @ 10:47 am
Thanks @ianmelville That did the trick!
geposted Wed 15 Feb 12 @ 11:50 am
No problems and don't forget to go Pro and register for all the VDJ goodies that are free on this site
geposted Wed 15 Feb 12 @ 12:00 pm
I tried to follow the instructions yet I can't find the applications tab in the task manager
geposted Sun 25 Mar 18 @ 2:32 pm
The post is 6 years old so it's for an older version. Even if you are on the same os I don't think the issues will be the same with current versions
geposted Sun 25 Mar 18 @ 2:36 pm
Leeeeeeeee, please don't open threads over a year old. Start a new thread, and explain {b]YOUR problem in detail, thank you.
Locked for being old by AMAHM
geposted Mon 26 Mar 18 @ 6:58 pm
