Hey Folks,
I currently have installed in my club gear box my Denon DNHC-4500, which as many would know uses ASIO drivers. My question is, if I wanted to mix at home WITHOUT the DNHC4500, but I wanted to use, say the Numark DJIO to mess around with, record, etc. would there be potential conflicts since both use ASIO drivers? If not, can I use the IO along with the DNHC to have 4 stereo decks, or would that lead to bad things?
geposted Wed 15 Feb 12 @ 3:44 pm
I just started with VDJ Pro. I have a Denon MC6000 and as a back up, the Numark DJ2Go and DJ/IO. So I can answer the first part of your question.
I installed the driver for the IO today. After you install both drivers, you will be able to choose which one you want to use in the Sound Set up. Just make your choice and you're good to go.
I tested everything today, switched back and forth from the Denon to the DJ/IO, no problems. Good luck.
geposted Wed 15 Feb 12 @ 4:32 pm
So you'd be using the same computer (and VDJ) for both locations, just using the 4500 at one and DJIO at the other?
Sounds like a job for the SBDJ profile switcher plugin thingy.
https://virtualdj.com/addons/12300/SBDJ_Profile_Switcher.html
geposted Wed 15 Feb 12 @ 6:02 pm
Yes, groovindj..i think lol.
I want to leave the 4500 in the install box at the club and use the DJIO (or an equivalent card) so I can mix at home. And, if I can use both at same time to have 4 stereo decks while I'm at the club. Would the SBDJ Profile Switcher help?
geposted Thu 16 Feb 12 @ 2:16 pm
I think so, yes.
But if you're happy to go into config each time you start VDJ (with different hardware) to change the sound settings, you could just do that.
geposted Thu 16 Feb 12 @ 3:34 pm
