In the download Plug-ins section, there are 2 Equalizer plugs-in available, a 1-band and a 32-band (both from the same user).
I'm a VDJ Pro User using the latest version, attached to a Denon MC6000 controller.
When either version of the EQ is installed and activated, it causes the Master program music to stop playing (replaced with a loud humming sound for about 10 seconds). It does this then the jog wheel is touched on the deck you're going into.
Deleted the plug-ins; all works fine again.
Maybe the plug-in isn't compatible with 7.05; and if anyone knows of a good EQ plug-in that will work on V7, please let me know.
Thanks,
Doug
Thanks,
Doug
geposted Wed 15 Feb 12 @ 6:52 pm
