Topic: virtual dj/numark dj2g0 mappers
just picked this up, pretty cool
i am new to this so i have some questions
does anyone know if i can program the pitch bend buttons to be kill switches for bass and treble? in the mappers section?
or turn the volume buttons into the treble dial?
and it anyone could lead me to a good place to learn about the programming aspect side of this that would be great
thanks
geposted Thu 16 Feb 12 @ 5:24 am
Yes, you can map it to do just about anything you want. Go into Config, Mappers, and select Numark DJ2GO from the drop-down list. The left pane shows the current mapping, which you can change/add to as much as you want. See the following page for info on the available commands:
https://virtualdj.com/wiki/VDJscript
but you need vdj pro to be able to map....
Good point
