As the title state, I would love to see a bit of a tutorial on your use of VDJ effects in song transitions. What effects you may use together, how
you use the effects, etc. If this interests you, please keep explanations simple and easy to understand =D I'd love to hear from all of you and
what you guys like and utilize. Thanks as always community!! =D
geposted Thu 16 Feb 12 @ 4:17 pm
I think that the best way to find out what they do and what would work for different transitions is to play around and experiment with them until you find something that works for you,I know you want an explanation on how they work but if you practice A LOT you won't need it.
Good luck.
Good luck.
geposted Thu 16 Feb 12 @ 11:08 pm
Good luck.
Good luck.
+1 on that. And depending on what your mixing you don't even need an effect when transitioning :)
geposted Fri 17 Feb 12 @ 3:17 pm
the mix lessons section has a discussion about this that sexeral of us added large amounts of knowledge into. i suggest you strt there.
geposted Sat 18 Feb 12 @ 5:01 am
