hello, my vci 100 doesnt have a headphone jack, so im assuming the is a way you can cue up tracks with your headphones through your computer?? Ive tried hooking my headphones up through my headphone jack on my computer and tried different sound settings and options, and can't get anything to work. there are cue buttons for listening to tracks on the vci 100 so im assuming there is a way.. any suggestions would be great... also in vdj7 is there still an automix function where you can set up a playlist on the right and it will play the songs automatically...i remember this option being in older versions of vdj?? if there is how do you get to autromix? thanks guys dj jonny m
geposted Fri 17 Feb 12 @ 12:03 pm
The VCI-100 doesn't have a built-in sound card. Please see: https://virtualdj.com/wiki/Pre-listening%20with%20headphones.html
Regarding automix, please see the section entitled PLAYLIST & AUTOMIX in the user manual for VirtualDJ: https://virtualdj.com/wiki/PDFManuals.html
geposted Fri 17 Feb 12 @ 3:23 pm
I have an external soundcard.. (audio 2 DJ by native instruments) do I need a soundcard with more channels than 2 or is there a way to split the signal between my computers soundcard and my external one so I can use the computer soundcard for cueing and use the external soundcard for output to speakers thanks Jon
geposted Fri 17 Feb 12 @ 7:38 pm
No need to use two soundcards.
The Audio2DJ hold eberything you need.
Input - None
Output - Headphone
Soundcard - ASIO and beside selected the Audio2DJ
Set at ASIO Config 4ms and 8ms (VDJ Config - Soundcard)
Install before the latset drive from NI, related to the Audio2DJ
Then connect the Output A, while using the provided cables, with your speakers!
Insert at Output B your Heaphones and you are ready to go!
Input - None
Output - Headphone
geposted Sat 18 Feb 12 @ 3:49 am
