Forum: Old versions
Topic: Hey everyone quick question
So i was in the middle of a mix and windows updater decided to shutdown everything and restart the comp. i was 36 minutes in and it was going well.
upon rebooting, the file was there on the desktop but wouldnt play in itunes! nooo, right? well i tried to open it in VLC media player, it worked fine!
my question is. Is there anyway to make that file that works in vlc un corupt and work in itunes?
i mean it works in vlc theres gotta be a way, any help is much appreciated!
thx,
Ols
geposted Sat 18 Feb 12 @ 3:44 pm
What kind of file?
Does the track play in Virtual DJ?
Keith
thanks keith,
The file is a .wav and no it wont play in vdj it says error. To state again it will play in vlc media player. I wonder if i have to convert it to a different file type. it wont play in vdj, itunes or winamp just vlc... weird.
Thanks
Ols
download "audacity" open the wav, then save it as an mp3. hopefully that will work for you... you can also change the format vdj records in to mp3 in the "recording config" screen.
i bought the Hercules dj console RMX, with it came the cd for the installation, this is my problem I misplaced the cd cover where my serial number is and now I can not finished installing it. any help out there? need my serial #
synthetic
i tried what u said. Audacity wont even load the .wav. when i saved it as an mp3 the file didnt work in anything it was like a half second of nothing then file stopped.
yet the original file still works in vlc.
this is getting strange haha vlc for the win but im just curious now if i can get it to play in anything else.
thanks for the replies.
ols
I googled a bit and found this:
Try Wave Agent and let us know what happens.
http://www.sounddevices.com/products/waveagent.htm
OR (don't know if this is possible,i f not it definately should :)))
Try playing it with VLC then use another program to record the sound coming out of your speakers and then you have the song.
Or you can try and google for "corrupt wave file" , there seem to be a lot of "fix corrupt wave file" programs out there, like Goldwave, Wav saver
Stievie Gonzales
thanks alot for the tips im going to try them the next few days. Im workin 12 hr days so im gettin around to that file at a snails pace. greatly appreciate the replies! I will report back! heh
p.s i like your second idea haha or i could just ... re do the mix ahha but im a techi so ill waste time and try and see if i cant help someone down the line whos in the middle of something and the system shutdowns for whatever reason.
cheers,
ols
yo yo,
Alright i finally got to the file. Thanks for the awesome advice audicity did the trick in like 2 minutes.
I imported the corrupt file by going "import raw data" then saved it by going "export" and saving it as an mp3.
Super easy super awesome thanks a lot and have a great weekend!
cheers,
Ols
Hi there I bought a hercules rmx console a few years ago, but now i want to re-sell it to a new dj, my question is this, I want that person to be able to register his copy (my old copy) which I will complete erase from my software or updates as soon as I sell it, I also want to give him the serial so he can use it and get his updates under his email and he does not have to rely on me to get him the updates,.. is that posible? a few years ago I updated my controllers so i don't need the hercules remix anymore., how can I do all that?
Sorry, this is not possible. VirtualDJ serial numbers are not transferable and cannot be sold or given to any other user - Please see: https://virtualdj.com/wiki/Serial%20Transfer.html - Your VirtualDJ Console Edition serial is also part of your Pro license because you used it to upgrade at a discount.
You can sell the console to him and include the original Hercules Console Edition CD to allow him to install the original VirtualDJ Console Edition that came with it, but he will not be able to register the serial and will not be entitled to any software updates, plugins, etc. For this, he will need to purchase his own license for the full VirtualDJ Professional: https://virtualdj.com/buy/
NOTE: Console Edition for RMX is not entitled to any updates beyond v5.2.2 and doesn't support custom skins, effects, etc. outside of the 20 day trial of Pro (v5.2.2)
