had a strange issue with my virtual dj last night mid set it decided to start scrolling to the bottom of any list i clicked on (folders/track/auto play list/side list) no idea what caused it had been working fine all night then just decided to start this scrolling problem, after restarting vj it was fine, it may have been coinsidence but it started at the same time i pressed play on the right deck of my dac 3, tried to disconnect the controller but problem remained
geposted Sun 19 Feb 12 @ 9:22 am
Maybe a button the controller (Down browsing button) got stuck and/or didn't send its release message?
Because the rubber buttons of a controller are often all attached together on one sheet, pressing PLAY could have been enough to also push the DOWN button, especially if it is getting worn due to use and/or sticky due to dirt, etc. getting into it.
The DAC-3 is well known for failing buttons.
geposted Mon 20 Feb 12 @ 7:30 am
that may have initially been the problem but i unplugged the controller and it stil stayed the same so 5 mins later i plugged the controller back in
geposted Wed 22 Feb 12 @ 2:26 am
It could also be caused by a sticky key on your keyboard (E.g: Page down) or the mouse scroll wheel (Constantly scrolling down.)
With some scroll mice, clicking the scroll wheel will activate constant scrolling (Moving the mouse up/down affects speed and direction.)
Also, if you are using the native mapping for the DAC-3, the UP/DOWN buttons repeat when the button is held down, so if it sticks down it will keep repeating (scrolling) until it's released (Unplugging the controller may not count as releasing it.) You'd need to click the button again.
geposted Wed 22 Feb 12 @ 7:29 am
ok well i dont use a mouse i use the laptop mouse pad if i used the up arrow the tracks would scroll up but as soon as i released the button it scrolled to the bottom again, it's never done it before until sat night i'm working again tonight so will see if the problem occurs again (i hope it doesn't) but if it does will try and get a video of it happening
geposted Wed 22 Feb 12 @ 10:37 am
It could have been the mousepad causing this. Although usually touching it again will normally release it.
geposted Wed 22 Feb 12 @ 11:20 am
i never touched the mousepad to start it though was reallt strange but i can report tonights gig not a problem
geposted Wed 22 Feb 12 @ 7:17 pm
