Has anyone created a MAC version of this -
https://virtualdj.com/addons/13908/Beatmasher_Single.html
I just got a Midi Fighter and would really like to use this effect with it.
Thanks
Thanks
geposted Sun 19 Feb 12 @ 2:30 pm
you can use Tex ZK's loop roll instead, it is lacking the 3/4 and 2/3 roll size, but it has reverse for a bit of variety. I'll put up a basic mapper and a working definition file with leds in a couple of days, but you are definately better off making the mac dual boot and using windows for vdj.
geposted Sun 19 Feb 12 @ 2:46 pm
Really? Why is that?
I've used VDJ on my MAC for over a year now with no issue.
*knock on wood
geposted Sun 19 Feb 12 @ 3:01 pm
just for the plugins, i'm sure vdj is fine on osx, but there are definately more extras on the windows version at present.
also what effects do you get natively with the mac version?
geposted Sun 19 Feb 12 @ 3:05 pm
I'm working on improving that situation :-)
geposted Sun 19 Feb 12 @ 3:08 pm
LED's would be cool... as of right now, my MIDI FIGHTER just lights up when I hit a button.
Midi mapping is still new to me, but figuring this thing out is helping me learn.
geposted Sun 19 Feb 12 @ 3:44 pm
This is the starting poing I have been experimenting with so far on my Midi Fighter...
Top Row 4 Buttons (L to R)
set '$shift' 1 while_pressed & wheel_mode "browser" while_pressed
var '$samp' ? sampler default loop 50% : var '$shift' ? loop_move -4 : loop_half
4 '$samp' ? sampler default loop : var '$shift' ? smart_loop : loop
var '$samp' ? sampler default loop 200% : var '$shift' ? loop_move +4 : loop_double
Second Row From Top 4 Buttons (L to R)
down ? effect 'Flanger' active on : effect 'Flanger' active off
down ? effect 'FlippinDouble' active on : effect 'FlippinDouble' active off
down ? effect 'BeatGrid' active on : effect 'BeatGrid' active off
down ? effect 'EchoDoppler' active on : effect 'EchoDoppler' active off
geposted Sun 19 Feb 12 @ 3:52 pm
Any update ???
geposted Wed 29 Feb 12 @ 7:40 pm
theres a bug in one of the commands i wanted to use to change deck focus, i'm not going to upload until it's fixed which needs to be updated to work from atomix's end, but pm me your email and i'll send you one that changes with the pfl selection, it's not as good doing it that way imo...
but i did figure out how to make looproll make any size you want within 8 beats, cant believe i never tried it before... just disable the quantise button ;-)
there is unfortunately no lfo filter as ther isnt one ported to mac.. so i replaced it with flanjet which sounds pretty good, it has cut (gate) an automated noisebell (sweep) and i think echodoppler (freeze), but if i left that out i'll put it in
geposted Wed 29 Feb 12 @ 8:34 pm
Could this be what you are looking for? It says that I am not licensed to download the plugin and it's probably because I do not have VDJ but I might want to switch to VDJ so I wanted to look into this question also.
geposted Wed 14 Mar 12 @ 5:52 pm
It's only available on the PC at present.
geposted Wed 14 Mar 12 @ 7:19 pm
