Hi,
I am trying to use a Denon hs-5500 with OS X but in the audio settings in advanced config the sound card isnt being recognised and the only options for each deck are channels 1 and 2.
When I use the same device on my laptop with the windows version I get the 5500 sound card available and choice of channels 1 and 2, 3 and 4, 5 and 6, and 7 and 8.
Does anyone have any ideas what the problem might be?
Thanks,
Dale.
Thanks,
Dale.
geposted Sun 19 Feb 12 @ 5:22 pm
You may need to configure it for multi-channel audio. Some sound cards (Particularly older ones) may not do this automatically under MacOS.
Please see: https://virtualdj.com/wiki/Configure%204%20channel%20audio%20on%20Mac.html
(This is for configuring 4 channel audio, but if your card has more channels than this, simply choose the appropriate number.)
geposted Mon 20 Feb 12 @ 6:49 am
