Forum: Old versions
Topic: problem with korg nano pad mapping
I have download the drive for the korg nano pad, but is not showing in virtual dj ,how to solve this issue? thank you
(sorry for my english,if there are mistakes)
geposted Mon 20 Feb 12 @ 10:46 am
is the nano pad working with the LE virsion of VDJ?
No, LE only works with the controller it was included with, except during the 20 day trial of Pro.
NanoPad doesn't come with VirtualDJ LE included.
Only the full Pro supports using any native supported controller of your choice.
NOTE: If you use Pro trial in VirtualDJ LE, then depending on the age of the controller that it came with, it may not be the latest version and won't have support for newer controllers. You can check for a newer version of VirtualDJ LE by going to https://virtualdj.com/users/edit.html and registering its serial number to your profile. Then go to the Download Center: https://virtualdj.com/download/updates.html - In most cases, VirtualDJ LE will give you a discount off the cost of upgrading to the full Pro.
