Hi. I am running Virtual DJ Pro with a Hercules RMX, two turntables with Serrato Gen 2 time code vinyls and a Windows Vista laptop.
I have had this problem occur a few times and have tried to resolve it with no real success.
Sometimes after a while of DJing, usually a couple of hours, one of the time code vinyl signals goes hay-wire and causes songs to suddenly skip rapidly forward or backward. When I try to fix this problem I will find that the signal this is occurring on will show a vertical line instead of a nice circle in the time code vinyl adjusting section (the other signal will be fine). I have tried using different TCV drivers, but ultimately I have to re-boot to fix the problem. Is there something that I need to adjust or update. Please let me know if you need further clarification. Thank you.
geposted Mon 20 Feb 12 @ 2:06 pm
I just tried messing around with the grounding wire from the turntable that was acting up and it may have resolved it... seems to be working now. I will keep you posted and in the meantime if anyone else has other ideas please let me know. Thank you.
geposted Mon 20 Feb 12 @ 4:19 pm
