Ok instead of making the same mistake I did 2 years ago and just going out to buy a high end laptop I am going to ask if the new laptop I am thinking of buying will have any issues. The last laptop I bought had video mixing issues supposedly for problems with it having an ATI card. I tried all the fixes that were posted here in the begining but none of them work so i gave up on it. That was the past soooo....
Please tell me if the laptop I think I am going to get is going to have any problems with video mixing.
HP Model: dv7-6c95dx
Processor: BrandIntel®ProcessorIntel® 2nd Generation Core™ i7Processor Speed2.2GHz (with Turbo Boost up to 3.1GHz)
Display: TypeHigh-definition widescreen LED-backlit with BrightView technology (1600 x 900)Screen Size (Measured Diagonally)17.3"System Memory: (RAM)8GBSystem Memory (RAM) Expandable To16GBType of Memory (RAM)DDR3 SDRAM
Hard Drive Size750GB (5400 RPM)
Optical Drive: DVD±RW/CD-RWOptical Drive SpeedsDrive speeds not specifiedDirect-Disc LabelingNoDigital
Media Reader or Slots: Yes, digital media card reader
Graphics: Intel® HD Graphics 3000TV TunerNoMPEGYesBuilt-in WebcamYes
Modem: NoneNetworkingBuilt-in 10/100/1000 Gigabit Ethernet LAN (RJ-45 connector)Wireless NetworkingWireless-B+G+NBluetooth-Enabled
NoS-Video OutputsNone
AudioBeats AudioSpeakersInternal
PCMCIA SlotsNoneUSB 2.0 Ports2 USB 3.0; 2 USB 2.0IEEE 1394 FireWire PortsNoneParallel PortsNoneGame PortsNoneLaptop WeightStandard (more than 5.5 lbs.)Battery LifeUp to 9 hours and 30 minutesPointing DeviceTouchpad with illuminated LED border and on/off buttonHDMI OutputYesBlu-ray PlayerNoOperating System PlatformWindowsOperating SystemWindows 7 Home PremiumSystem Version64-bitIncluded SoftwareAdobe Reader, Adobe Flash Player and moreENERGY STAR QualifiedYesBest Buy PC AppNoGraphics ChipIntelWireless Capability4G WiMAXDrive Capacity750GBGraphics CardIntel® HD Graphics 3000Wireless DisplayYes
geposted Mon 20 Feb 12 @ 4:56 pm
The specs are good but the Video Card is Not. If you are just play HQ videos, It will be fine but, HD videos, maybe not. All the new videos are being released in higher resolution.
geposted Mon 20 Feb 12 @ 6:53 pm
Personally I would steer clear of the HD3000. I bought a new laptop recently and went with a Clevo.
http://www.novatech.co.uk/laptop/range/eliteultimate2760.html
Very impressed with the performance.
geposted Mon 20 Feb 12 @ 8:39 pm
Been using a Macbook Pro and no issues also running a Numark NS6 with it.
geposted Wed 22 Feb 12 @ 4:48 pm
http://www.msimobile.com/level3_productpage.aspx?cid=6&id=340
Bought this a month ago and love it,lighted keyboard,3 gig video card,1.5 terrabyte hard drive space,16 gig ram,awesome soundcard,high def anti reflective screen.
geposted Wed 22 Feb 12 @ 5:13 pm
sbdj looks like a sweet machine mate.can you use all the memory for vdj as a gig machine only.can you also upgrade to a bigger size sshd
geposted Thu 23 Feb 12 @ 2:27 pm
No, because Virtual DJ is still a 32-bit application and thus is subject to the constraints of WoW64.
You can fit an SSD and a second hard drive/SSD in place of the DVD if you want.
I tested a fair few machines and this one had acceptable DPC latency out of the box unlike most.
geposted Thu 23 Feb 12 @ 10:09 pm
