effect "Brake" active ? on blinkfast : off
this may confuse it as they are two different commands,change it to just
effect "Brake" active ? blinkfast : off
Also lpd 8/mpk mini pads are retarded, they send a led off signal everytime you press the button, Zestoi from Djism and an active member on the dj techtools forum (and hopefully when I finish convincing him a vdj user and developer) Has created an incredibly powerful program to overcome traktors mapping issues, In his program he has created a way that on receipt of the led off message from the lpd, it checks with the software, if the led is supposed to be on it will light the pad back up, But you shouldn't notice any change...
I am still trying to figure out how it works, but If you contact zestoi I'm sure he would be happy to help.
http://midimasher.djism.com/
geposted Wed 22 Feb 12 @ 11:38 pm
Thanks a lot for quick answer... Unfortunately it didn't work. LEDs are acting like without mapping - stays on only when I hold it, as soon as I let go it goes off..
I'll check that website...
Thanks again...
Any other ideas?
Thanks again...
Any other ideas?
geposted Thu 23 Feb 12 @ 7:07 pm
So I've checked the midimasher, but didn't know what to do... Also sent a message to Zestoi - thanks for the tip...
Anyway, meanwhile I was playing with mapping file for lpd8 and lpd8 editor and I've found out that if I switch to "toggle" just 2nd preset it works just fine (meaning the pads from 2nd program stay lid while the button is active). It works just for PADs not for CCs...
geposted Thu 23 Feb 12 @ 9:50 pm
