The TRAKTOR KONTROL S2 is discount for $399.I'm thinking of buying one monday.Just need to know if any of you guys own one and how is it.
Your opinion well appreciated.
geposted Fri 24 Feb 12 @ 5:59 pm
It's not currently natively supported by VirtualDJ, so you would need to map it yourself.
We'd strongly recommend purchasing a controller that's already natively supported by VirtualDJ:
https://virtualdj.com/wiki/VirtualDJ%20Controllers.html
geposted Fri 24 Feb 12 @ 7:12 pm
One of my mates has one and uses it with Traktor. Quite plastic and cheaply built.
Keith
Keith
geposted Sat 25 Feb 12 @ 3:20 am
Keith
Keith
OMG !!
cheaply built ?? are you sure ?
is not working ok with Vdj , but it's a good controller .
I think we should be objective when talking about controllers .
s4 & s2 are good ones .
cheaply built :
Numark Mixtrack or Dj Tech
Quite plastic - plastic it doens't mean BAD . Cdj2000 are 90% plastic .
I found this : link removed
Moderated - Please do not post links to off-site mappers
geposted Sat 25 Feb 12 @ 10:51 am
i have created a S2 mapper that is 100% free to VirtualDJ Pro users, you may find it in the plugins download section, i also have an S4 mapper thats undergoing testing that im sure the atomix staff will be more than happy to provide you with if you required it.
geposted Thu 15 Mar 12 @ 5:45 am
what about the soundcard of S2? DOES IT supported only with asio4all drivers?
geposted Thu 15 Mar 12 @ 12:06 pm
NO , it works perfect with Ni drivers .
geposted Thu 15 Mar 12 @ 12:51 pm
I love the s4 , costs 998.00 im waiting to map it when the virtual dj 8 comes out.. so many sick features...
geposted Thu 22 Mar 12 @ 7:33 pm
i have numark cue/vdj pro, traktor s2 controller, downloaded your mapper and put them in correct folders (mapper & definition) i installed the driver for the s2 and all seems ok, but i still cant get it to control vdj? am i doing something wrong/ missed something? thanks
geposted Fri 13 Apr 12 @ 5:39 am
Installed s4 mapper. Downloaded from the plugins. How do I choose the s4 mapper in vdj. Is it suppose to 'just work'? Because it 'just doesn't' right now?
Anyone?
Bc
Anyone?
Bc
geposted Mon 07 May 12 @ 8:59 pm
