My setup includes 2 Denon S3700's and a Denon X1600 Mixer. I've been using VDJ for years without any problems. Recently, I've been experience audio dropouts while looping tracks. This is usually brought on by 8 bar loops; however, it occasionally drops during 4 bar loops as well.
Audio drop outs happen briefly, for a couple of seconds and then it kicks back in. Happens on audio and video tracks. Any tips/ideas/suggestions on how to fix this? I haven't changed any preferences.. I did add a couple of plugins a few months ago.
geposted Sat 25 Feb 12 @ 7:23 am
Yes, I'm experiencing the same thing.
My setup: Stanton scs1d (2x) and one Stanton scs1m (asio, firewire).
Os: WinXP pro (32bit)
VDJ: 7.0.5b
The dropout occurs for no reason after some time (there does not seem to be a pattern here).
Audio dropouts only occur on the looping deck and only for the duration of the length of a loop (1 bar, 2bars, etc.).
After the dropout the audio comes back, but after some time dropouts may occur again.
Wish I could test an older version, but my hardware is only (native) supported by the latest (7.0.5b).
Looks like this guy is also having the same issue:
https://virtualdj.com/forums/151824/MAC_Version_Technical_Support/7_04_-_Loop_-_Audio_Drop_Out.html
I wonder what we all have in common that makes the software behave like that.
VDJ: 7.0.5b
geposted Thu 08 Mar 12 @ 3:15 am
I think I've figured it out! This works for me in my setup, but it basically comes down to this:
If using ASIO make sure your soundcard driver is set to 48k!
Since there is no other way (for me) than to use ASIO, I've checked the Stanton SCS1m driver settings:
Turns out that daRouter uses 44.1k by default. I changed this explicitly to 48k.
I haven't had any loop dropouts since I changed this (haven't tested it well enough, but so far so good).
But here is the catch (for my setup): as soon as VirtualDJ quits, this setting resets itself to 44.1k.
So everytime I start to use VirtualDJ I need to manually set the Stanton driver in daRouter to 48k first.
geposted Thu 08 Mar 12 @ 7:39 am
My previous statement about changing the samplerate and it magically works, turned out to be wrong. After some time the dropouts occured again. Which was very frustrating, so I took the time and went over the settings step by step.
I found a solution to my dropouts using the following procedure:
- backup the current mappings/skins (if you happen to have any custom ones)
- reset vdj to factory defaults
- (important!) make sure that on the Mapper tab NO checkboxes are checked in the options section (so no "Use keyboard, Use HID" etc.)
- restart pc (just in case, and make sure above still hold)
- in soundsetup, select your output setup (mine was advanced config, asio outputs)
- test the soundcard for dropouts using your mouse on the skin (selecting loops, playing with pitch) and make sure audio is working fine
- after being sure audio is working fine, select the "Use keyboard, use HID" or whatever is applicable to your setup on the Mappers tab
- restore any mappings/skins
I'm not quite sure why this procedure works, but the order in detecting a new soundcard and adding new controllers apparently matters.
This might not help you with your dropouts, but I guess it is worth a try...
geposted Sun 11 Mar 12 @ 1:16 pm
Has this worked long term for you?
geposted Mon 28 May 12 @ 2:51 pm
