Hey
I have recently got really addicted to mixing and i really enjoy adding effects and stuff like that.
But i havent bought a single pece of hardware.
I wasent planning on spending a whole bunsh of money.
But i found some peces i really think i would enjoy.
(the site is norwegian, but half of it is written in english)
http://www.multima.no/Avdelinger/Lydutstyr/MIDI/Kontrollere/DJ/Numark/Numark-MixTrack-Pro-DJ-Software-controller-w-audio-interface-MixTrackPro-p0000002221.aspx
http://www.multima.no/Avdelinger/Lydutstyr/MIDI/Kontrollere/Tangenter/Akai/Akai-LPK25-Midi-keyboard-25-tangenter,-portabel-LPK25-p0000000011.aspx
http://www.multima.no/Avdelinger/Lydutstyr/MIDI/Kontrollere/Pads/Akai/Akai-LPD8-Laptop-Pad-Controller--LPD8-p0000000010.aspx
Do you recommend any other peces of hardware or something else?
Thanks in advance :D
geposted Mon 27 Feb 12 @ 1:26 pm
I am using the mixtrack pro and it's awesome, the only thing is the plasticky feeling it gives you but beside that everything is perfectly good for beginner to professional. Plus it's cheap since you don't wanna spend much on the hardware
geposted Mon 27 Feb 12 @ 10:07 pm
